Flexible LED Work Light with Magnetic/Spring Clamp Base
Cast a swath of bright light in nearly any environment with this flexible LED Work Light. With two mounting options-a powerful magnet that attaches to any ferrous metal surface, plus a sturdier, reinforced spring clamp that grips onto shelves, bench tops and more-this makes a useful portable lighting option for a variety of tasks. Use it when servicing your table saw or changing planer blades, or use it on your bandsaw or router table for better visibility. With easy mounting and adjustability, the choice is truly yours.Features: Powerful magnetic base with spring clip and silicone pad to prevent scratchesFlexible neck adjusts to any positionRubber covered on/off button keeps out dust
