2002 Jeep Liberty Engine Control Module A1 Cardone Jeep Engine Control Module 79-1601V
A1 CARDONE ENGINE CONTROL MODULEA1 Cardone components are guaranteed 100 percent computer tested to secure product performance and reliability. Upgraded OE design flaws and make certain that chips will not rise from the board which was the usual cause of failure.A1 Cardone Engine Control Computers are designed to maintain better-quality electrical connections, avoid irregular malfunctions, controls emissions, and regulate fuel consumption.Features:ISO 9001, ISO 14001, and ISO/TS 16949 tested100 percent resolder of major componentsDefective OE conformal coating is removed from the entire ECM board including underneath chips and replaced with enhanced conformal coating
