1973-1979 Honda Civic Water Pump GMB Honda Water Pump 135-1131 73 74 75 76 77 78 79
GMB OE REPLACEMENT WATER PUMP, NEW -- Includes 1 rubber gasket; Features a high flow design that provides long lasting and efficient cooling; Designed for OE fit and performance; Factory lubricated for long life; The precision ground shaft and hub accept OE fan clutches perfectly; Its OE quality forged housing is specially formed to ensure maximum coolant flow; Precision built and balanced with its pressed on impeller that increases water flow; The unique no-sealant required gasket makes installation fast, easy and leak-free; Its unitized seal protects bearings that provides long life and leak free performance; Features factory sealed precision ground one piece bearing; Engineered, designed, and built using the strictest design and manufacturing guidelines; With the finest quality assured through ISO 9002 programs; Easy installation; With lifetime GMB limited warranty... Auto Parts Warehouse has extensive GMB Water Pump catalogs.We are now offering FREE shipping on all GMB Water Pump orders over $50.00. Our secure gmb water pump catalog is available every hour of everyday. Shop with confidence for all your gmb water pump needs. GMB Water Pump are In Stock and available today. Save up to 60% off dealer price on your next GMB Water Pump purchase. Our online catalog contains a wide selection of the OEM and aftermarket parts you need at unbeatable prices
